Skip to content
Introduction ​
Basic Configuration of MagicMirror² ​
  1. Go to your configuration directory: In Bash/linux, it'll be in ~/MagicMirror/config/
  2. Create and edit a config.js by using your editor of choice.
  3. Minimum configuration requires the following:
    js
    const config = {
          module: "clock",
          position: "fullscreen_above",
          config: {},
    if (typeof module !== "undefined") {module.exports = config;}
    See module configuration for more information and examples.
  4. Run your magic mirror. Refer back to installation if you're not sure how to do so.
More useful configuration of your MagicMirror ​
These directions assume a linux/bash style command line, and previous instructions followed. If not, please insert the path directly from your installation.
  1. Copy ~/MagicMirror/config/config.js.sample to ~/MagicMirror/config/config.js.
    Note: If you used a third-party installer script, this step may already have been done for you.
  2. Modify your required settings using your preferred editor. nano is the easiest.
  3. You can check your configuration running node --run config:check in ~/MagicMirror.
The following properties can be configured, place them above the modules item:
OptionDescriptionDefault Value
portThe port on which the MagicMirror² server will run on. This may need to be changed in specific advanced installations, below.8080
addressThe interface ip address on which to accept connections. The default prevents exposing the built-in webserver to machines on the local network. To expose it to other machines, use: 0.0.0.0.localhost
useHttpsEnables HTTPS for the built-in web server. Most users can leave this at false unless they intentionally run HTTPS directly in MagicMirror². If enabled, you must also set httpsPrivateKey and httpsCertificate.false
httpsPrivateKeyPath to the HTTPS private key file, used only when useHttps is true.""
httpsCertificatePath to the HTTPS certificate file, used only when useHttps is true.""
ipWhitelistThe list of IPs from which you are allowed to access the MagicMirror². Add your IP when needed. You can also specify IP ranges with subnet masks (["127.0.0.1", "127.0.0.1/24"]) or directly with (["127.0.0.1", ["192.168.0.1", "192.168.0.100"]]). Set [] to allow all IP addresses. For more information see: ipWhitelist HowTo["127.0.0.1", "::ffff:127.0.0.1", "::1"]
zoomThis allows to scale the mirror contents with a given zoom factor.1.0
languageThe language of the interface. (Note: Not all elements will be localized.) Possible values are en, nl, ru, fr, etc. for the full list see: List of ISO 639-1 codesen
timeFormatThe form of time notation that will be used. Possible values are 12 or 24.24
unitsThe units that will be used in the default weather modules. Possible values are metric or imperial.metric
electronOptionsAn optional object of Electron (browser window) options. This allows configuration of e.g. screen size and position (example: electronOptions: { fullscreen: false, width: 800, height: 600 }). Kiosk mode can be enabled by setting kiosk: true, autoHideMenuBar: false and fullscreen: false. More options can be found here. This will most likely be used in advanced installations, below.{}
electronSwitchesAn optional array of Electron switches. Use strings for switches without a value and object entries for switches with values. Each object can contain one or more switches.
This setting will not affect the serveronly mode. Usually normal MM users don't need this property, but if you are a hard-core hacker, you might need this to handle Electron itself over MagicMirror provides. More options can be found here (Not all available switches are described there.)
example:electronSwitches:["no-sandbox", { "js-flags": "--max-old-space-size=8192" }, { "password-store": "basic" }];
ignoreXOriginHeaderIf set to true, remove X-Frame-Options from response headers in Electron, allowing more pages to be embedded in iframes. Advanced use only; this can reduce security protections.false
ignoreContentSecurityPolicyIf set to true, remove Content-Security-Policy response headers in Electron. Advanced use only; this can reduce security protections.false
customCssThe path of the custom.css stylesheet. The default is config/custom.css.config/custom.css
watchTargetsAn optional array of file paths to monitor when using node --run server:watch. When any of these files change, the server automatically restarts and connected browsers reload. Particularly useful when frequently modifying config.js, custom.css, or module files during development or setup. Example: watchTargets: ["config/config.js", "config/custom.css", "modules/MMM-MyModule/MMM-MyModule.js"]. See Development Mode for more details.[]
After the above options, you will then add modules. See module configuration for more information.
Advanced configuration and frequently asked how to configure examples ​
Legacy and power-user options ​
The following options are real and supported, but they are intentionally kept out of the main options list because they are specialized:
  • tls (default: null) is a legacy compatibility option. Avoid it in new configurations. For HTTPS setup, use useHttps, httpsPrivateKey, and httpsCertificate.
  • userAgent (default: auto-generated) can override the User-Agent used by server-side module requests. It can be a string or a function returning a string. Most users can ignore this option.
Advanced runtime options ​
These options are valid, but you typically only need them for advanced setup or debugging:
  • checkServerInterval (default: 30000) controls how often (in ms) the client checks whether the server process changed.
  • reloadAfterServerRestart (default: false) enables automatic client reload when a server restart is detected.
  • httpHeaders (default: built-in helmet config object) allows overriding server security header behavior.
  • hideConfigSecrets is documented in detail in Secrets.
When you use functions in config.js, keep them inside the exported config object if they need to be available in the browser. MagicMirror² serves the browser copy of the configuration from the config object, so free-standing helper functions outside that object are not included there.
Bash Environment variables ​
There are two environment variables that override part or all of config.js. They are:
Environment Variable NameUse
MM_CONFIG_FILEThis specifies an alternate configuration file for the system. This is useful when running multiple mirrors on the same device. NOTE: this file MUST be located in a directory within the MagicMirror directory. Ideally, place any config file in the config subdirectory.
MM_PORTThis specifies an alternate TCP/IP port, overriding "port" item within the config file. This is useful for testing to see if the product will run using another port.
mmFetchTimeouttime in milliseconds for fetch timeout. default (30000)
this value can be used to adjust the nodejs fetch function timeout value for all node_helper modules that use fetch()
Examples of use ​
You have created two config files, named config.js and config2.js
By default, you would use config.js with a bash script (mm.sh):
bash
cd ~/MagicMirror
node --run start
To use the 2nd configuration file, use a bash script like this (mm2.sh):
bash
cd ~/MagicMirror
export MM_CONFIG_FILE=config/config2.js
node --run start
To change the port:
bash
cd ~/MagicMirror
export MM_PORT=8081
node --run start
You can run node --run config:check on your 2nd configuration file by typing the export line in first, example:
bash
log
[26.12.2023 18:13.12.972] [INFO]  Checking file...  /home/<user>/MagicMirror/config/config2.js
[26.12.2023 18:13.13.062] [INFO]  Your configuration file doesn't contain syntax errors :)
Environment variables inside the configuration file ​
Since MagicMirror² version v2.35.0 curly braced bash environment variable are allowed inside the config.js file. This allows you to use variables to replace hardcoded options. When starting MagicMirror² the variables are resolved. This is most useful for tech support provided on the forums and sharing your configuration.
Variables must be inserted as ${MY_VARIABLE}, examples:
config.js:
js
const config = {
	address: "${MY_ADDRESS}",
	port: ${MY_PORT},
	useHttps: ${MY_HTTPS},
would be translated to
js
const config = {
  address: "localhost",
  port: 8080,
  useHttps: false,
Defining variables ​
There are 2 ways to define variables, you can mix as needed or desired. If a variable is defined in both ways the linux environment variable is used.
Using a config.env file ​
This file must be in the same folder as the config.js and contains the variables, using the example from above:
File content of config.env:
log
MY_ADDRESS=localhost
MY_PORT=8080
MY_HTTPS=false
Using linux environment variables ​
Define them before you start MagicMirror², in a bash script, for example:
bash
cd ~/MagicMirror
export MY_ADDRESS=localhost
export MY_PORT=8080
export MY_HTTPS=false
node --run start
Using electronOptions ​
The most common use for electronOptions is a dual monitor setup on a Raspberry Pi 4 or greater. To do so, you can launch a second MagicMirror and use electronOptions to move it over to the next monitor. For example:
You have two 1920x1080 monitors set up in the Pi as sitting next to each other: Screen-Layout-Editor
To move the pi to the second monitor, use this:
js
const config = {
	electronOptions: { x: 1920 },
A Couple of Real World Examples ​
Two Screens ​
A user has two monitors running on a Pi4B. User wants to show cameras on one monitor, and wants to show informational panels on the other. Monitors are set up as above.
User would have to set up two config files, and two starting scripts to do so. User would use method of choice to launch starting scripts (e.g.: PM2).
Starting Script 1 (mm.sh):
bash
cd ~/MagicMirror
node --run start
Starting Script 2 (mm2.sh):
bash
cd ~/MagicMirror
node --run start
Configuration file 1 (config.js):
js
const config = {
	address: "0.0.0.0", // Can be whatever you set as your original.
	port: 8080, // Must be different than the other configuration file.
	ipWhitelist: [], // Can be whatever you set as your original.
	language: "en",
	timeFormat: 12,
	units: "imperial",
	//logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
	(insert module configurations here)
	] // end of modules
}; // end of config variable.
/*************** DO NOT EDIT BELOW ***************/
Configuration file 2 (config2.js):
js
const config = {
	address: "0.0.0.0", // can be whatever you set as your original.
	port: 8081, // Must be different than the other configuration file.
	language: "en",
	timeFormat: 12,
	units: "imperial",
	] // end of modules
config.js with variables ​
User likes to help German language users in the forums. As such, he wants to be able to paste bits of his config.js into the forums to show as an example, but don't want to share his private data, and has a hard time remembering to remove them from the config.js file.
config.js:
js
const config = {
  address: "0.0.0.0",
  port: 8080,
  ipWhitelist: [],
  language: "de",
  logLevel: ["INFO", "LOG", "WARN", "ERROR"],
  timeFormat: 24,
  units: "metric",
      module: "MMM-RAIN-MAP",
      position: "bottom_left",
        animationSpeedMs: 400,
        colorizeTime: false,
        defaultZoomLevel: 8,
        displayTime: true,
        displayClockSymbol: true,
        displayOnlyOnRain: false,
        extraDelayLastFrameMs: 2000,
        markers: [
          { lat: ${LAT}, lng: ${LON}, color: "black" },
        mapPositions: [
          { lat: ${LAT}, lng: ${LON}, zoom: 9, loops: 1 },
          { lat: ${LAT}, lng: ${LON}, zoom: 8, loops: 1 },
          { lat: ${LAT}, lng: ${LON}, zoom: 7, loops: 1 },
          { lat: ${LAT}, lng: ${LON}, zoom: 6, loops: 1 },
        mapUrl: "${MAPBOX_URL}",
        mapHeight: "320px",
        mapWidth: "520px",
        updateIntervalInSeconds: 300,
      module: "MMM-Strava",
      header: "Strava",
        client_id: "16228",
        client_secret: "${STRAVA_API_KEY}",
        activities: ["ride"],
        period: "recent",
        stats: ["count", "distance", "elevation", "achievements"],
        auto_rotate: true,
        updateInterval: 20000,
        reloadInterval: 3600000,
        showPrivateStats: true,
        limitPrivateStats: 1200,
        digits: 0
      module: "MMM-OpenWeatherForecast",
      header: "Wetter",
      position: "top_center",
        apikey: "${OPENWEATHER_API_KEY}",
        latitude: "${LAT}",
        longitude: "${LON}",
        showHourlyForecast: false,
        colored: false,
        iconset: "3c",
        label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"],
        concise: false,
        forecastHeaderText: "",
        label_sunriseTimeFormat: "k:mm",
        label_high: "",
        label_low: "",
        displayKmhForWind: true
      header: "Termine",
        timeFormat: "absolute",
        showEnd: false,
        dateFormat: "DD.MM.",
        maximumEntries: 10,
        maximumNumberOfDays: 70,
        colored: true,
            symbol: "subway",
            url: "${CAL_URL1}"
            symbol: "cake-candles",
            url: "${CAL_URL2}"
            symbol: "angle-right",
            color: "#999999",
            url: "${CAL_URL3}"
Matching config.env example (fake urls and locations):
bash
LAT=0.0
LON=0.0
MAPBOX_URL="http://example.url/1458562"
STRAVA_API_KEY="FakeKey1234"
OPENWEATHER_API_KEY="FakeKey4321"
CAL_URL1="https://calendar.google.com/calendar/ical/example@example.example/private-fakeaddress12445812581119058955b/basic.ics"
CAL_URL2="https://calendar.google.com/calendar/ical/example@example.example/private-fakeaddress2445812581119058955b/basic.ics"
CAL_URL3="https://calendar.google.com/calendar/ical/example@example.example/private-fakeaddress32445812581119058955b/basic.ics"
For other help with setting up a more complex Mirror, please visit our forum.
